If(word exists in discription dimension) help please
Hiya,
I have a description field like a verbatim field and im wondering how to group instances if certain words are in the description.
for e.g.
if a description contains the word Insurance i want to tag it as Insurance related and so on.
any ideas as i cant seem to find a contains function in webi?
cheers :slight_smile:
Ben Elford (BOB member since 2010-04-27)
Check the Match() function.
Im looking to try and icorporate that into an if statment, some thing like below
=If([Case Details] Match([Case Details];“Insurance”);“Insurance Realated”;“Unkown”)
which would group all the case details containing insurance into one group called insurance if that makes sense.
The formula should look like this:
=If( Match([Case Details];"*Insurance*");"Insurance Realated";"Unknown")
Thats spot on!!
thanks for you help on this one :smiley:
You’re welcome 8)
One additional note:
If the word Insurance can be written with the mix of small and caiptal letters then it’s better to convert the string to upper case before using the Match() function. Something like this:
=If( Match(Upper([Case Details]);"*INSURANCE*");"Insurance Related";"Unknown")
