Hi guys,
this is a quite simple If-then-else clause:
if isnull({S_OPTY.YARD_ID}) and ({S_OPTY.Primary_ID} = {S_OPTY.MANAGER_ID} or {S_OPTY.Primary_ID} = {S_OPTY.OWNER_ID})
then “Owner/Manager”
else “Others”
The situation:
Case1: The Primary ID = the Manager ID. Owner ID and Yard ID are empty.
Case 2: The Primary ID = the Owner ID. Manager ID and Yard ID are empty.
For case1, the result of the formula is “Owner/Manager”.
For case2, the result will be “”. That’s false. The result must also be “Owner/Manager”.
If I change the order of the “or”-terms in the brackets, the results would be vice versa. (Case1: “”, Case2: “Owner/Manager”)
Why this? It seems that the order of or-terms is important for Crystal. Is there any solution to avoid this?
Thx a lot in advance and best regards.
IDr
IDr (BOB member since 2009-10-20)
