IE7 compatability
Hello,
We currently have XI R2 (.net) installed and accessing infoview and webi through IE6. We have a project on the horizon which will move us to IE7 and I have been asked to check that Infoview and Webi will continue to function.
Trying to search for a system requirements document on the SAP website is painfull to say the least. Does anyone here know the answer?
Cheers
Kedge
kedge (BOB member since 2007-02-14)
The support site seems to change frequently, right now you can find the PAR by going to the SAP Support Portal, pick the Help & Support tab and then SAP Business Objects Support. From the left hand side, pick Documentation and then Supported Platforms. You need a login to the site.
Gillian :uk: (BOB member since 2005-08-18)
