I have a universe in which the tables are derived tables that have @prompt in them.
for example something like this:
SELECT * FROM TABLE@Prompt('Company Group:','K',{'123','124','145','156','167','168'},mono,constrained )
Each table end refers to a different table with the same structure but different data.
I want to stop using the @prompt, and switch to a parameter, that can easily be maintained (when there’s a new table ending, I need to add it to the @Prompt manually in 30 tables).
But I haven’t seen the K option, and when I use the parameter in the syntax - it doesn’t parse properly.
Has anyone managed to get something like this to work or knows of a workaround?
