I need to correct all the IDOC errors appeared in SAP system. I have BO data services 3.2 version install. Do i need to install BO Rapid mart? the interface where i can see all the error idoc list and can correct it and send back to the SAP system. I have experience on data services sap workflow. i am new to IDOC.
RapidMart has nothing to do with IDOCs, not even with SAP loading, it reads the data from SAP.
I am not sure what the goal is, is it to correct the dataflow and rerun it? Is it to read all IDOCs that have not been processed inside SAP because of an error in the data? There are status tables for IDOCs, don’t know the name of these yet.
The Goal is to pull the IDOC which has erros into BODS and the provide report with error details. Based on each error the interface to correct the error and send it back to SAP
i am also looking for the same requirement. If any IDOC fails while BODS is processin, .i want to send a mail with IDOC number to the concerned persons. Can you please share the solution… if you already have
