Idoc creaating duplicates in ECC
I am loading Fixed assets in to ECC, My source table have no duplicates at all.However when I review the results using trans we05, I see that the records are duplicating and I end up having multiple records for the same asset.
Can some please assist.
Extreamrav :south_africa: (BOB member since 2011-08-23)
This could be due to a wrong nesting in your query statement when building the IDoc output.
Have you tried to output the IDoc to file/disk and limit the input to a single asset to see if your data flow is either generating duplicate IDocs or if a single IDoc contains repeated data?
Otherwise, you could use BD87 to examine of your most recently loaded IDocs and see within the IDoc if it contains duplicate data or if a second IDoc exists with the same asset data. In the latter case, WE10 may be useful to search for all IDocs containing that particular asset.
ErikR :new_zealand: (BOB member since 2007-01-10)
Thanks for you response.
If i populate a single assest I dont get duplicates.
Will try loading to a file.
