system
1
Can anyone help with this one. Can BO tell me if a Name has symbols in it…
example. John O’Shea
Need to highlight this name as it contains a apostrophe (’)
I need to create an exception report that identifies all names that contain some kind of symbol. Only Letters or Numbers are allowed.
Many thanks
Zahed
Sims786 (BOB member since 2006-04-04)
system
2
Hi Saima786,
Create a variable :
=If (User Name or Object name) IN (‘give all the special characters here’);‘then display your text message’;’ ')
Now you can get all the names with special characters.
Let me know if I understood correct way.
RK
krohanstar (BOB member since 2008-04-20)
system
3
Tried this
=If ([Standardpayeridentification] In (’*’);“Inv”)
got following error
The date/time ‘*’ format at position 39 is not valid. Specify a valid date/time format. (Error: WIS 10035
Have I done something wrong
Sims
system
4
Please check if you are validating are of same datatypes.
What is the datatype of ([Standardpayeridentification])
RK
system
5
HI,
Do not use “Inv” (No double quotes " " in Webi)
Hope this works…
RK
system
6
You need to use a logical test something like:
=Match([Name];"*'*") Or Match([Name];"*-*")
Your problem is knowing which special characters to include in your list!
What are you going to do with these records anyway? Why not use the Replace function to remove the special characters.
You are far better doing this kind of data manipulation in the database anyway.
anorak
(BOB member since 2002-09-13)
Its an Exception report to highlight these symbols in the database name fields. The User would then go into Database and correct
thanks
Sims
I don’t know what John O’Shea would say about that!
anorak
Do you have a list of Characters that could possibly appear in the Name?
M H Mohammed
(BOB member since 2010-06-16)
system
10
Try using ASCII values for comparison.
Jansi
(BOB member since 2008-05-12)
