system
1
In my report consists of several report tab in it.In the report we are using Prompt.
So in that prompt i need to give access to user so that they can view particular tab by applying Prompt conditions.
So after applying the prompt conditions they can view one particular tab instead of viewing all the tab in the report.
How we can do this?
Sabari
sabari11@gmail.com (BOB member since 2008-09-17)
system
2
Setting focus on a particular tab using a prompt value is not possible
If you can tell why you need it that way then a workaround can be suggested
There can however be other ways, like using vB macros which may or may not work
And delete your duplicate post here
haider
(BOB member since 2005-07-18)
system
3
Ok.
If there is anyway to do this in a report.
Why i am asking is, this was the questions asked to me in a interview.
system
4
So you know now that its not possible out of the box
There is a sticky topic here in General discussion forum for interview related questions, you can post there for further queries
haider
