I can not start CMC!
I can not start the CMC from Central Configuration Manager.
Everytime I click start it stops right away. What could be the problem?
please advise
Swimmer :netherlands: (BOB member since 2006-08-23)
check the event viewer on the windows server.
Maybe the repository DB is not reachable.
hyder
it all works fine now, see https://bobj-board.org/t/85101
Then you should have kept one thread/post rather than having multiple with same queries. Because both were interrelated problems.
at first I did not know it was caused by the same problem. sorry. you can close this subject
