I am installing SAP Business Objects BI 4.0 Platform
Hi Team
I am installing following tools in Windows 7 and 64 bit.
BIPLATCLNT4103_0-20009642.EXE BI
While install getting error like “BI platform client 4.0 installed Failed”.
PLease find the attachment.
Kulanthaivelu (BOB member since 2014-04-03)
fyi… this is the webi platform, not the DI platform…
it looks like you are attempting to install using the update application vs the full installer… the update application requires that an older version of the software already be on this machine…
under the sap portal, try the other installations and upgrades section vs the packages and patches section.
ww55d (BOB member since 2011-06-14)
I have to install Webi Universe Tool. So What i have to do.
The following tools needs to be installed for Webi.
  1. BIPLATCLNT4103_0-20009642.EXE
  2. BIPLATCLNT4103P_2-20009642.EXE
Please give me suggestion.
This is DI forum not BO. You have to post it in Webintelligence forum for the answers.
Arun.K :us: (BOB member since 2011-10-18)
Topic moved, thanks
BIPLATCLNT4103_0-20009642.EXE is an update for an existing installation (SBOP BI Platform Clients 4.1 SP03 - Update), not a full installation. You need to download the full installation file for SP3 (SBOP BI PLATFORM 4.1 SP03 CLIENT TOOLS WINDOWS (32B)) and install it instead. Then you can apply the patch.
thanks for information. I have installed. It’s working fine.
