Our environment is being upgraded to BO XI 3.0.
I spent some time looking into its new features and also seeing whether our reports in R2 SP2 work fine in 3.0.
Here I found that hyperlinks are not working. Theres a new way to create hyperlinks using a wizard in 3.0. Its very user friendly- with the code getting generated automatically as you browse to select the report. The code generated is similar to the code we already had for R2- so I believe ideally hyperlinks created in R2 should have worked without any changes in 3.0.
But the directory of opendocument.jsp has been changed in 3.0 installations.
It is not found in this directory :- /businessobjects/enterprise115/desktoplaunch/opendoc/openDocument.jsp.
For most hyperlinks changing
/businessobjects/enterprise115/desktoplaunch/opendoc/openDocument.jsp? in R2
To
…/…/opendoc/openDocument.jsp? in 3.0
Is working fine.
Can anyone suggest what changes the environment admins should do- to ensure Opendocument.jsp is available in “/businessobjects/enterprise115/desktoplaunch/opendoc/openDocument.jsp”? Should they reinstall Tomcat?
If this is not resolved we need to go to each report with a link and change them- and we have lots of those
Roshknee (BOB member since 2007-10-29)
