Hyperlink Sort Order
I have a table which has 3 levels of drill.After drilling to the last level there is a hyperlink from the last drill level.In the table the hyperlink can be shown properly by changing its type to hyperlink but on converting it to hyperlink, the (sort)order does not remain same with respect to graph’s legend.Is there any way to make names match with the graph’s legend?
sreekesh (BOB member since 2007-12-27)
Does anyone has a solution for the above problem, I am facing the same problem.
boosterbroek (BOB member since 2009-06-11)
