HyperLink Problem
Hi all
I have an report which is having the hyperlinks for the use of referring some other reports, If so the user click any one of the links in that report, has to take from the corporate documents and from the categories, I don’t know how to write the macro to get the result
Please let me know how can I do it? If you have the code also that would be great help me to understand the logic., hope get reply from you guys.,
Thanks in Advance
Vish
visu (BOB member since 2005-05-31)
If you have access on techsuport, see if you can find here (but don’t ask me where exactly ;-)) a document called “hyperlink white paper.doc” dealing wity this subject
Bernard
hi
I dont have access.
vish
hi Bernard
Do You have that doc. If yes means plz send it. How to access techsupport.
vish
http://www.techsupport.businessobjects.com
You have to ask to your sales peoples, if you have valid contract and contact with Bo to open you a login/password to access it.
Take a look at this thread.
