I am facing 2 issues related to hyperlink in WebI 3.1.
1> I want to hyperlink a Id column from a “Summary tab” to “Detail tab”. Here users will select/Click the Id from Id Column in “Summary” tab to view the related detailed data in detail tab. I am aware this was easily do able in XI R2 but I am unable to do it in XI 3.1, even by using relative hyperlinking.
Need some help with a sample code to implement. - Concern : how will the data pass dynamically from summary to detail. need an example.
2> I have few sets of parent > child >sub child > sub sub child…>…n.
I need to know , how can i implement this scenario using hyperlinking in the same report, using different tab of the report. Is it feasible…??
As far as I’m aware the ability to link to a particular report tab was only introduced in 3.0, So, I will be intersted to see this!
As far as I’m aware you will have to spawn multiple copies / open doc calls to acheive this functionality.
I don’t think from your description of the problem that this will work for you.
Please help me with the 2nd scenario I mentioned earlier. I am fine even if you suggest me with few workarounds. I am actually currently preoccupied and would appreciate if 2nd scenario works out for me.
Waiting for few ideas so that i can implement it.
I would be updating with the workaround solution for 1st item very soon.
