hi all, I have created a universe on BEX query. while creating the report am not able to find the SQL/MDX query it has generated for the Report. Is there a way to find out the Report SQL for Bex Universes.
Thanks in advance
Regards, Suneel.
suneel445 (BOB member since 2009-09-17)
For any OLAP cube based universes , currently in BOXI 3.1 SP2 - you cannot see the MDX through report panel. However you have two options.
There is a way to set registry entries to capture the logs. SAP support might be able to provide more details on that.
The way we do it, is that we run a tracer on the cube, so any queries that BO fires against the cube can be captured.
ramaks (BOB member since 2009-03-31)
