I have a report and I want to write a macro for deleting zero rows of two columns.And if shouln’t be like if zero in one column and some value in the other then it should display both the columns.Delete only if both the columns hav zero’s.
DataGenius (BOB member since 2006-06-13)
Can’t you create a condition in the query panel that would limit the data that are fetched into the report?
And if you can’t and the 0s are already in the report why can’t you use a filter to filter out from a data block the rows that you don’t need them?
actually the qury is not so simple.The only solution is do it by using macro.I need a macro.Please write me the code for macro for this.
You can’t really delete or even edit rows via a macro. The data is not exposed at that level.
There are options for building complex filters that can check more than one column… meaning it’s more than just a simple “picklist” of values. That’s probably the route you need to go.
I am not sure whether I understand correctly what you want.
Using macro you can set a filter on a data block to hide some rows. Some examples of such macro can be found in DK (VBA/ASP/JSP) section of BOB.
However, macro can not be used to delete records from a data provider. This is not possible.
Can u send me code how to hide those rows of the columns.Or can u write me a macro that can be used in excel.
Have you tried search in SDK (VBA/ASP/JSP) subforum?
yeah I tried but unfortunately didn’t find one over there.I believe it is not the complex one.
Here is an example how to add a complex filter:
Author: Dwayne Hoffpauir, EDS Corporation
Further discussion should take place in this topic .
The attached report uses VBA to create a separate report tab filtered for each value of a given field. The sample is based on the Island Resorts Marketing universe, and creates a separate report tab for each resort. The report tab name for each is changed to reflect the filtered value. The first tab is cloned as many times as needed, then the original tab is deleted from the document. The VBA cod…
