How to use VBA to get SQL stt of variables and print out?
Hi all,
I need to extract the SQL stt of a variable in a report and print it into a text file.
To further explain my “SQL stt of a variable”, in Designer, if you click the ‘Properties’ of a variable, you can see what is written under ‘Select’.
I need to write some VBA codes to extract these from a report to a text file and I really have no idea how to go about doing it…
I think I have to declare a universe variable, include the designer’s variables, then after that I really am lost…
Does anyone has a full solution for this lost soul?
Thank you so much.
obeel :nonod:
obeel (BOB member since 2004-02-10)
You can download from Bob’s Downloads the Excel Utility for mass update of a universe :
Mass update to object names / descriptions
The next step - replace the GetInfo procedure with the following one:
Sub GetInfo()
    Set DesignerApp = New Designer.Application
    DesignerApp.Visible = True
    Call DesignerApp.LoginAs
    Set Univ = DesignerApp.Universes.Open
    DesignerApp.Visible = False
    Set Wksht = ThisWorkbook.Worksheets("Objects")
    Wksht.Unprotect
    Range("Objects").ClearContents
    Call GetObjectInfo(Univ.Classes, 1)
    Range("Objects").Resize(Wksht.UsedRange.Rows.Count - 1, 5).Name = "Objects"
    Range("Objects").Columns("D:E").Value = Range("Objects").Columns("B:C").Value
    Wksht.Protect
    DesignerApp.Quit
    Set DesignerApp = Nothing
End Sub
You`ll be able to save the document as text or whatever.
sharone (BOB member since 2002-10-17)
