How to Use Reports from 'Crystal Report 2008' in 'BO XI 3.1'
How can we use the reports in the .rpt format from “Crystal Report 2008” server to be included in the “Business Object XI 3.1”.
I tried using the “Import Wizard” of the “Business Object XI 3.1”, however, there is no option to import the .rpt file. :frowning: It is asking for the BIAR file. :?
Can’t I import .rpt file?
Is there any other wizard in “Business Object XI 3.1” which can help me importing the reports from Crystal Report 2008 into BO XI 3.1?
Is ther any document available whicyh can help me to solve this prob.
Thanks in advance.
surbhit4u (BOB member since 2009-06-30)
In Crystal Reports Designer.
File -> Save As -> In the dialog along the left is an icon which says Enterprise. Login to CMC. Save report.
Done.
Or use Publishing Wizard to do a batch of reports.
I am now able to publish the reports in BO XI.
However, I am now stuck @ integration.
I am using struts project with Tomcat.
How can I integrate the Crystal Report with my web project ??
Thanks in advance
