How to use output of report object to decide scheduling
I have a requirement where I need to implement following
There is one object in a report that should decide whether the same report will be scheduled successfully or not.
In other words, if object a is used in report then if value of a is ‘Y’ then report scheduled runs successfully otherwise not
aberiwal (BOB member since 2012-03-15)
Take a look here:
https://bobj-board.org/t/151998
HTH
