There will be blanks where no records exist for that intersection so there is actually nothing there to be not null, it’s simply an empty intersection.
You can get round it by entering 0 in the cell and then use an alerter to display the actual data with a basic bit of logic.
SELECT a1 as Row, b1 as column, 10 as amount
UNION
SELECT a2 as Row, b2 as column, 12 as amount
UNION
SELECT a1 as Row, b2 as column, 14 as amount
If you create the above as a freehand dataprovider, you will get a simple table with three rows in it
a1 | b1 | 10
a2 | b2 | 12
a1 | b2 | 14
Now convert that to a crosstab and you will see that nothing exists at the intersection of a2 and b1 - you cannot replace it with 0 because there is nothing there to replace!
What you need to do is have the cell as 0 and then create the alerter as If Not(IsNull(Amount) Then Amount) (obviously with correct syntax )
But in my case i need to calculate Sum(Amount) foreach(salesoffice), here for few there is no data and when i apply that formula it showing wrong result due to Matrix. (Multiplying twice of each occurrence)
So i thought to divide that formula by Count of each. Now actual problem coming if it has values then it working good but if no values exist it’s failing in that case. So moved to make that empty/null to 0 to add to the context.
Am i doing right thing??
P.S: All values are coming dynamically(OLTP system), I can’t do it in report.
