How to use feature toggles in SAP Webi
As of 4.3 SP4 feature toggles can be defined in the CMC. I am not familiar with these toggles and documentation is scares. Where can I find the available feature toggles and how do I use those in a WebI report?
A real life example would be great.
Thx,
What do you have (e.g., link, screenshot, etc.) that mentions “feature toggles”? I am unfamiliar with what you are talking about.
this is from the SAP documentation What’s New in Web Intelligence 4.3 SP4 | SAP Help Portal
And here’s a screen shot from the Webi application properties in CMC:
… instead of editing ini/config/xml files in the depths of the BO-directories (and repeat the whole thing after updates),
you can now set a switch to turn on/off some features.
I can’t see any official function yet, but this can perhaps be used for e.g. switch-on data-combining in “Data-Mode”, which has not yet been officially activated
