Hi all, I have SAP BO 4.0 SP 2 patch 16 installation. During the upgrade process to SP 04 we discovered that our install.manifest - file created during original instalation is corrupted, so we want to uninstall BO 4.0 SP2 and want to install BO 4.0 SP4. Could you please help how to do it when try with add/remove programs doesnt work and also when I run new installation wizard and choose option ‘remove’ i will receive error - internal error detected. See log for details. Thanks a lot for any idea !
Zahid Yener replied
January 02, 2012 at 14:06 PM
I had the same problem a while ago. I solved this by
1. Go to folder C:\Program Files (x86)\SAP BusinessObjects\InstallData
2. Under this file you'll find "InstallManifest.sqlite" file. You need to open this file through SQLite editor. You can download it https://addons.mozilla.org/en-US/firefox/addon/sqlite-manager/ as an add-on to your firefox.
3. There are 13 tables in this database. Go to "DUTransaction" table. You will see "Committed" column change the value if there is any zero 0 value to 1.
4. Save and close the file.
5. Restart your installation.
This should solve your problems.
Going forward for you, a friendly advice: what saved us a ton of headaches, was to take a full snapshot of the box we are upgrading, including snapshot of the database. This way, you don’t need to uninstall anything and risk bad install going forward by simply reverting to the pre-upgrade state.
