Hi Gurus,
I had created a formula in Crystal Report.
Employee Count = distinctcount({Employee Name},{States}).
This is displaying correctly by States.
VA=100
CA=500
FL=300
How to display Total sum of Employee Count (900) on the report footer?
Ordinary count is not working here. Some reason it is displaying last row value on Total field. In my case 300 is showing instead of 900 in RF. Please help…
First insert distinct count on {Employee Name} and place this in {States} group footer then insert count on {Employee Name) and place this in Report footer.
Note : Use Insert Summary option in CR to insert distinct count and count in group footer and report footer respectively.
hi,
CR does not support any functions like sum, Max, etc once you created formula using count or distinctcount. Example sum(count(Employee name)) does not support…
