How to start?
I need to write VBA code to read the query results on report, and based on results send an e-mail to the users.
The e-mail sending procedure I have, How to get query results?
Where to start writing the code from?(for the SDK beginner…)
What objects need to be used? :confused:
Any suggestions really, greatly appreciated
Thank you very much,
DAR
darina (BOB member since 2002-12-03)
You want to read from the DP or from the report. These are two different things and the latter is not that flexible. But this has been discussed lot of times on this board. A quick search for Data providers on SDK Forum will yield some good results. Here is one such which will give you a preview of how it is done.
How can I get data from BO using VBA?
Sri
Sridharan :india: (BOB member since 2002-11-08)
Sri,
Thank you very much for responce
Sri,
I have a free-hand SQL and need to read data from the report.
If you have a samples, please send it to me. Your help greatly appreciated.
Thank you,
Gimme your email I will send one such one. But it may not be complete though.
Sri
