BusinessObjects Board
How to sort objects in a class
Hello
I would like to sort the objects in individual classes in Designer. Is there any way I could do it.
The users want it like this, since its easier for them to search for the objects while creating a report?
Appreciate any help
Namit
namitrs :us: (BOB member since 2006-11-28)
The sort feature is called “drag and drop”. :wink: Drag the objects into the desired sort order. That’s the only way to get them in the sort order that you want. 8)
yeah, I know the ‘drag n drop’ way :smiley: . But it will be crazy to do, that even for abt 400 objects…
So am trying to find a much less labour intensive way
Thanks for your reply though
Maybe there is a nasty hack that would involve modification of BO repository data. But it’s possible only for BO v6 and below. Not possible in BO XI.
Anyway, sorting objects in a class brakes default hierarchy. So it’s not considered as a best practice to sort objects.
I would argue that using default hierarchies is not a best practice. :wink:
