How to setup CMS for BODS for job scheduling
Hi all,
I am trying to schedule few BODS jobs from admin console.
I have setup time and everything but it doesnt kick off at that time. created and activated the schedules. I came to know I need to setup CMS in order to get this working. Kindly help me in figuring out how to setup CMS.
server is on UNIX, Repo DB is ORACLE, BODS vers 3.2
Thanks in advance
jbodi (BOB member since 2011-09-07)
I don’t think you have do any setting in CMS, you can check if the CMS is enabled to run java program, you can check this from CMC, go to Applications-> CMC , by default the CMS is enabled to run java program
you can also set the default OS user under which you want to run the program
if you are able to create the schedule succesfully, you will see this in DataServices folder in CMC, go and execute the schedule and see if you get any errors, you should be able to see if some setting is missing from the error message
