I have a report that has a rather complex and long winding query to retrieve data from a Oracle database (Just moved to v9.2). With this move, query is taking too long to complete and the DBAs suggested setting the session parameter STAR_TRANSFORMATION = FALSE.
Question: How do we set this parameter in BO ? I do see the custom tab has some options, but it doesnt quite provide for adding new parameters. You can only set values for already available parameters. Is that right ? Or Am I missing something ?
Also the above is possible only for free-hand sql statements… What if I want to set session parameters for sqls From Universes ?
I’ve moved this topic to the General Discussion forum. If it’s just one problem report, then you don’t have to worry about universe questions? I don’t know how you do this, whether its just an ALTER SESSION command, I don’t think BO is really the tool to do this. I wonder if your dba can set a session based upon the user who signs in?
Thanks… You can say I am a newbie to BO. right ? :))
We explored the DBA setting it for users option, but we have too many users running too many reports; and we wanted only this report execution to have this parameter.
does that make sense ? Seeing all the values in the Custom makes that the ideal place to add more (once i figure out how to)
