dear, i did through the same way as you said. But even though i am unable to restrict the webi features to the respective user.
I wan to take the rights of âSorting, Break, Filter and etcâ
Rights are only working to stop âdrillingâ feature, other than this i am not able to do so. I am attaching an image so that you can see what i have done.
I have the attached an image for the rights which i gave to the user.
I have granted for following
Log on to Web Intelligence and view this object in the CMC âGrantedâ
Enable interactive HTML viewing (if license permits) âGrantedâ
Enable Query - HTML âGrantedâ
Enable Java Report Panel âGrantedâ
Enable drill mode âGrantedâ
Create document âGrantedâ
rest of them are denied. You can also view the attached file,
