How to restrict the data showed in a column?
I’m new in Crystal, I have the data from the database as:
APP_ID, STATUS, DATE
011 NEW 01/01/2009
022 NEW 02/01/2009
033 OLD 03/01/2009
I want to show in the report a cross-tab table but without using the cross-tab option from Crystal:
Date # of APPS by STATUS for example
Date | NEW | OLD
01/01/2009 | 1 |0
02/01/2009 | 1 |0
03/01/2009 | 0 | 1
Is there any way to use a where clause in the column like in WebIntelligence. For example, in the column new use a Count(APP_ID) where STATUS = ‘New’?
Luigi
luigif :australia: (BOB member since 2006-09-07)
That looks like just two formulas:
New Data: If <command.Status> = ‘NEW’ Then 1 Else 0
Old Data: If <command.Status> = ‘OLD’ Then 1 Else 0
Then use New Data and Old Data on the report.
BDeLong (BOB member since 2008-01-15)
Hi BDeLong,
Maybe I didn’t explain myself properly. I have several rows in the data containing dates, application codes and status. I need to create a cross-tab table that shows how many application I have by dates and status. Dates as rows and status as columns, how ever I need to create and extra column at the end to calculate a % between values of an expecific status against the total. Because the body of the cross-table is a count, I can’t see decimals in the new calculation (coutn of application for a specific status/total count of applications). Additionaly I need and extra row at the bottom of the table to calculate the daily average. The data will be grouped by months and I need to calculate the total count of calculation in a month / number of dates in that month. I can’t get the report to show me the number of dates in every month. If I use distinctcount(dates) I get the total number fo dates even if the cell is in the group.
Hope you can help me with this.
Luigi
