How to remove Characters from middle of string
Hello All,
How to remove first 5 characters and 5 characters from the middle of strings in crystal report. I have records like
YAINV1810WGTRL000004
YAINV1810WGTRL000005
YAINV1810WGTRL000006
YAINV1810WGTRL000007
I want to remove the string “YAINV” and “WGTRL” so that I get
1810000004
1810000005
1810000006
1810000007
Please Help
majijonah (BOB member since 2018-08-30)
If the strings are always the same length, then you can do this. Otherwise you will have to have a loop to check each character.
mid({somefield},6,4)+right({somefield},6)
kevlray :us: (BOB member since 2010-06-23)
Thanks kevlray, It works perfectly
