So far so good. You have created a variable of type DocumentVariable. You have assigned a local document variable to this item.
Nope, not going to work. The document variable has a number of attributes (like name, formula, etc.). You need to pick something out of the variable and use that.
That’s the BO way of saying, “You can’t do that with this.” You have a document variable, which is a parent object. You need a property from that object - like the name, or something - as mentioned earlier.
If you want the values for that variable, then you need to use a variant (array type) to store them in. Something like:
dim h1_values as variant
h1_values = h1.values(boUniqueValues)
Next, you can determine how many values there are using the UBound() function, and print out each value in a loop.
intNumValues = UBound(h1_values)
for i = 1 to intNumValues
msgbox "Value number " & i & " is " & h1_values(i)
next i
Yes, thank you very much.
I am referencing the local report variable which is defined via UserResponse in the BO document to archive the BO document as an excel spreadsheet with the file name “xyz archive promptvalue.xls”, for example “QC archive 2-1-2003.xls”
Unless I am misunderstanding what the “desired prompt of text” actually is.
I have put the following in:
Dim RepID as Variable
Set RepID = Thisdocument.Variables("Report ID:")
Report ID: being the actual prompt text. I am getting “Cannot find variable by its name” error on this. I have tried a variety of ways and get this error message or the 408 deal.
I am trying to pass a value in prompt to be used as the file name for saving data provider and report information into excel.[/code]
Hmmm… not sure why that didn’t work. This code will list all variable names in the immediate window, so you can verify that the variable exists.
Sub ListVars()
Dim Var As Variable
For Each Var In ThisDocument.Variables
Debug.Print Var.Name
Next Var
End Sub
Actually, I can’t even generate your error at all. I did the following
Dim Var as Variable
Set Var = ThisDocument.Variables("Bogus")
and it didn’t give me an error. It simply added Bogus as a new variable with no message at all. If you’re still having trouble, you might want to post the more complete code to see if it might trigger other ideas.
You have typed var as a Variable but are trying to use it as a DocumentVariable. That’s an easy thing to miss. Variables are application items, DocumentVariables are document items.
Also, Variables is a collection, if you want a single member of the collection, use the singular. As in:
Private Sub Document_AfterRefresh()
Dim var As busobj.DocumentVariable
Set var = ThisDocument.DocumentVariables("ReportID")
End Sub
I can obtain any information about the variable I want except for the piece that I want. The value of the variable. I still get a type mismatch error or a compile error if I try and use VAR.Values.
If I use VAR.Formula I get the formula of the variable.
How do I successfully obtain the value of the variable. I am combing the group and trying everything I can find, but not able to get a value.
Dim Var As busobj.DocumentVariable
Dim intVarCount As Integer
Dim myDocument As busobj.Document
Dim xlname As Variant
Set myDocument = ThisDocument
Set Var = ThisDocument.DocumentVariables("ReportID")
xlname = Var.Values(boUniqueValues)
MsgBox xlname(1)
End Sub
I have series of functions I wrote some time ago an drop them into most of the VBA work that I do. Included in those utilities is:
Function GetVariableValueCount(ByVal strVarname As String, ByVal intUniqueFlag As Integer) As Integer
' Parameters
' strVarname A string containing the name of the variable to check
' intUniqueFlag An integer value referencing a BO Constant that determines
' how the values are treated. Options are boAllvalues or boUniqueValues
' Return Value
' Integer value
' Parameters passed by Value to ensure that this routine does not change the values.
' This function scans the selected variable in the document and returns the number of values
' found. The count can be a unique count (boUniqueValues) or a count of all entries (boAllValues)
Dim intNumChoices As Integer
Dim varRequest As Variant
Dim boRequestVar As busobj.DocumentVariable
Set boRequestVar = boDoc.DocumentVariables(strVarname)
GetVariableValueCount = UBound(boRequestVar.Values(intUniqueFlag))
Exit Function
End Function
Function GetVariableValue(ByVal strVarname As String, ByVal intUniqueFlag As Integer) As Variant
' Parameters
' Return Value
' Variant, see below for details. May contain a string or array of strings.
' This function scans the selected variable in the document. If requested, it will verify
' the uniqueness of the value. The return item is either the unique value in a string, or
' an array of strings containing all of the requested items.
Dim boDocVar As busobj.DocumentVariable
Dim boVariableValues As Variant
Set boDocVar = boDoc.DocumentVariables(strVarname)
boVariableValues = boDocVar.Values(intUniqueFlag)
If (intUniqueFlag = boUniqueValues) And (GetVariableValueCount(strVarname, intUniqueFlag) > 1) Then
Call LogEntry("GetVariableValue", "Duplicate values found where unique expected.")
Else
If (intUniqueFlag = boUniqueValues) Then
GetVariableValue = boVariableValues(1)
Else
End If
End If
Exit Function
End Function
I am relatively new to VBA coding for Business Objects.
I was able to use some of the VBA code in this thread to get the various prompt values; but, can not figure out how to get the entire file name which includes various prompt values, text, and date to save as Excel. Included is excerpts from what I’ve been playing with:
Private Sub CommandButton1_Click()
Dim newFile As String
Dim ProvName As busobj.DocumentVariable
Dim ProvNum As Variable
Dim FiscalEnd As Variable
Set ProvName = ThisDocument.DocumentVariables("Legal Name")
xlname = ProvName.Values(boUniqueValues)
Set ProvNum = ThisDocument.Variables("Billing Number")
Set FiscalEnd = ThisDocument.Variables("From Service Date - End (MM/DD/YY)")
newFile = xlname(1) & " " & ProvNum.Value & " FPE " & FiscalEnd.Value & Format$(Date, "mm-dd-yyyy")
On Error Resume Next
ThisDocument.SaveAs (newFile & ".xls")
End Sub
