How to read (DS 4.2) Essbase data and load them to SAP HANA
In our project we like to load the cube data from Essbase to SAP Hana.
Obviously there does not seem to exist a generic datastore-type for Essabse?
manfred71 :austria: (BOB member since 2017-01-23)
I believe the way to do this would be via ODBC? Pretty sure there is a 64 bit ODBC driver available.
  • E
eepjr24 :us: (BOB member since 2005-09-16)
Essbase (Hyperion) is a multidimensional database (think SAP BW cubes or SSAS or TM1) and I do not believe that this is source that SAP Data Services may be able to query directly. Instead, you will need to configure Essbase to export the data into a relational database and have SAP DS pick it up from there.
See also: http://hyperioncenter.blogspot.co.nz/2014/11/essbase-load-and-export-sql-data.html
Edit: Having said that, there are ODBC drivers that appear to enable direct SQL querying against Essbase. However I have not seen any evidence that this actually works (it certainly hasn’t for me).
ErikR :new_zealand: (BOB member since 2007-01-10)
  • E
Have you managed to actually read complex Hyperion cubes that way? It hasn’t been very successful for me - instead, having Essbase export the data into Oracle worked quite well.
I have not… but you said it was not possible, which is quite different from not working well for you.
  • E
This is a forum, not an official SAP support site. So therefore everything we post is very much our opinion. Hence, my post reflected what is my opinion and it is very much opinion that this may not be directly possible. My sincere apologies for not making that explicitly clear.
I will immediately rectify my original post.
