How to point the BO Application to XI R2
Experts,
Recently BO upgrade is happened from XI R2 to R3 (BO 3.1) version in one of my project. The upgrade was successfull, but due to some reason, I have to point my Application again to XI R2 System.
The scenario is :
  1. XI R2 and R3 both are present on the server now.
  2. BO Application is pointing to R3 (BO 3.1 version) right now.
  3. I am trying to change the path (where BO has Installed) from New to old folder (e.g: D:\Program Files\Business Objects_R2 to D:\Program Files\Business Objects) but it giving me the attached error.
  4. I have restarted the server but the issue is still the same.
Since, I am new to BO, please help me in identifying the issue and how to resolve it so that I can use the BO application again which is pointing to XI R2.
Oracle User
Oracle_User (BOB member since 2011-03-11)
Can someone please reply on this. Need urgent help here.
Oracle User
Moderator note:
Please do not bump your post until at least one business day has passed.
Please also note that the forum is run by volunteers in their free time and for free. So if there is an urgent issue at your side, consider a paid consultancy help.
You won’t be able to use the 3.1 content in XIr2 anyway, as you have migrated it, there is no backward compatability.
Do you have the content on your XIr2 system, do you still have the XIr2 filestore and CMS database?
Please tell us why you have to do this? There may be some other way around.
I would suggest that dpending on what you still have, with regards to XIr2, your limited skills will limit what you could achieve in any case.
Hi MAK1,
yes I have Business Objects folder, File store and CMC of XI R2 with me. The reason behind doing such activity is few OLAP reports were not migrated to 3.1 due to licencing issue. Now, there is some enhancement requirement came in the same reports which are not migrated in 3.1.
So the idea is to point the application back to R2 so that I can start woking on the new requirement.
Please suggest with the old filestore and Business Objects folder can I point it back to XI R2.
Oracle User
So the old XIr2 system is now off line? You won’t be able to re-point as you suggest. You are supposed to be able to run side by side, although I have never tried.
Can you still see the XIr2 services on your server, are they all stopped? You could try stopping everything on the 3.1 instance and start up the Xir2 services. it all depends on what you still have intact.
Hi Mak1,
I have stopped all 3.1 services on the server and tried starting the XI R2 services, seems that few services are not started. They are:
  1. Connection Server
  2. Desktop Intelligence Report Server
  3. Input File Repository Server
  4. Output File Repository Server
  5. Report Application Server
  6. Web Intelligence Report Server
The reason is not clear to me yet. why they not started. Can you assist here.
Oracle User
[Moderator note - moved to the XI Servers forum]
The servers that haven’t started will have written some logging out. For example, on Windows you might look at the event viewer.
Is the XIr2 CMS database available and up and running? Paswords could have changed for accessing file stores / CMS database…so many things that could be wrong here. There is no way to troubleshoot this without looking at logs etc
