How to pass values between the tabs in a single report
Is it possible to pass values from one tab to other tab in a single report without using macros.
Thanks in advance.
nancy (BOB member since 2006-06-22)
Can you please explain the scenario why you need to paas the values from one tab to another tab?
Does Tab 2 depends upon the values in the Tab1?
It will be nice if you explain the scenario first.
Omkar Paranjpe :us: (BOB member since 2006-02-13)
In a report, tab1 one has summarized data. Tab 2 should have the detailed information about tab1.column 1.
I want to make it automatic instead of manually creating all the tabs because, tab1.column1 might have 20 values and in that case I will need 20 tabs with detailed data.
Please let me know if it is possible to do in deski.
Have a look at this post, it might do what you want: Create report tab and filter for each value
Gillian :uk: (BOB member since 2005-08-18)
Thank you. I will look into the VB code.
Gillian,
How to achieve the same in BOXI R2 (Webi) reports.
paryaniafroze :us: (BOB member since 2006-09-29)
