I want to connect to BO Enterprise using Crystal,How to change BO enterprise connection since i want to connect to Validation environment.
Naveen Vanaparthi (BOB member since 2008-07-02)
when you try and save the crystal report, it gives you the option of saving it to the enterprise and you just have to feed in the required BO/CMS server name and credentials to publish the report on the enterprise needed.
Cheers.
BO_Stuffed (BOB member since 2008-03-29)
