How to open Administration Console in BO 6.5.1
hello eveyone,
can anyone please tell me how to open admin console in BO 6.5?
there is one Administrator.exe file in bin folder of My BusinessObjects, but whenever I run that file I get a blank DOS screen.
Is there any other way to open admin console??
Malveka (BOB member since 2012-03-16)
Was there an Admin console in 6.5.1?? Sorry, I have totally forgot everything related to 6.5.1 except the fact that things are used to be simple!!
cpmohanraj :australia: (BOB member since 2002-09-23)
i have to increase the Maximum Binary output size limit as i am getting following error while downloading a report
“Maximum binary output size limit reached. Contact your BusinessObjects administrator.(Error: ERR_WIS_30271)(Error:INF)”
if there is no admin console, then increasing the limit will be practically impossible…
please help me !!!..
as this is very imp and urgent
Yep to deploy Webi …
If i remember this correctly… you have to right click on the Business Objects icon (a white icon with a blue dot) in the taskbar and click to launch admin console or admin Launchpad. I don’t remember the exact name, but i guess you can explore more once you are there.
Viru
viru4808 :australia: (BOB member since 2008-01-09)
Malveka,
Can you please let me know if you found solution for this.
Right now even I’m facing the same problem.
Whenever I’m running Admin Console I’m getting a Blank applet screen.
Can it be because of the version of Java is incompatible with the version of BO i.e 6.5.2? Since it uses “Java runtime environment”.
If so can some one tell me what is the compatible Version of JAVA for BO 6.5
krajuk :india: (BOB member since 2012-09-01)
