How to modify Section formula in the Report
Hello friends,
In the report, I’ve Section on the “User Name” Object. But now I want to have Section on “User ID” Object instead of the “User Name” Object. Please let me know how to do it which having to remove the “User Name” Section and then add “User ID” Section.
Thank you.
abhi_boxi (BOB member since 2010-02-04)
It should be a simple drag n drop operation, no?
You can drag the section header (User Name) out of the report and pull in the UserId.
mkumar (BOB member since 2002-08-26)
Drage th User Name Object back to the report, just make sure when you drage back object in th ereport make sure whe nyou see the green tip in the collumn then you drop and see message drop oject ,
but don’t drop when it will drop here to replace , thats all , and then you create new section
NidaKhan (BOB member since 2012-08-21)
That was simple :slight_smile: Thanks guys.
