Did anybody migrate MicroStrategy reports to BO?
Please help,
Thanks in advance!
manpreet_lall (BOB member since 2010-08-30)
Please help,
Thanks in advance!
Welcome to B:bob:B!
You will need to rebuild everything from scratch.
thnx fr the instant reply!
re-building will be a huge task, can you tell me any tips or helpline no./email id so that I can get help thoughout the process…
I am novice to BO.
any little help will be appreciable …
If you have SAP support, talk to them or else you need to hire a consultant to do this if its complex.
Or you have to get trained on BO.
There is no way to convert report which is built on some other tool.
Nits
Nits (BOB member since 2008-11-09)
Do you have experience with BO and MSTR?
Yes, rebuilding from scratch is tough. But no work is easy. If you have any specific issue when converting the reports, please post it. We have some folks who have converted BO reports to MSTR documents earlier.
Jansi (BOB member since 2008-05-12)
