How to migrate crytal 10 Reports to BOXI R3.1?
Hello frnds…
can anybody help me out with migrating crystal 10 reports to BOXI R3.1?
PLZ send any documents related to this
Thanks in advance.
Moderator Edit: Removed the email id from the post.
jyothibasu (BOB member since 2009-06-17)
All you need to do is install BOXI R3.1 onto another machine and then use the Import Wizard tool that comes with R3.1 to migrate your content from CE10.
jyothibasu, you can get all the free guides from SAP support site. Other than that please don’t ask the copyright materials to any of the B :mrgreen: Bbers.
A little research has never hurt anyone, most of the relevant documentation can be found via http://help.sap.com. In your case you’re looking for this document, you’ll need to have a proper login (S-id) to be able to acces it though. And might I add that it would have been more appropriate to simply bump up your previous post, instead of creating a new one. One other tip is to refrain from excessive punctuation like ??? and spelling like plz, as we’d like to keep the topics legible to everyone as much as possible.
wahey :netherlands: (BOB member since 2007-05-31)
There was another option for XI R2 (recommended for large installations) where you installed the new system, copied the CMS to a new location, copied the old FRS (Input and Output), set the new system to access the root directory where the new FRS resides, used the CCM to update Infoobjects, and used the Data Source Migration Wizard to migrate the data source of each report to a SQL Command in the new repository.
Is this still an option when migrating to XI 3.1? The Data Source Migration Wizard was targeted for .rpt files based on Crystal queries, dictionaries, or InfoViews. The Import Wizard seems like a much simpler solution; if an (CE10) installation has just Crystal queries, will the Import Wizard migrate the data sources?
charlie :us: (BOB member since 2002-08-20)
