I have a cross Tab reports .In that i have total pupulation column and need to make another column % of the Population
Total Population % of Population
100
200
300
200
1000(total)
I want to make a variable which shows the percentage of total population.
Pooja:)
ktm
(BOB member since 2008-11-12)
Try this
%=[Total Population]/Sum(Total Population) In Report
KhoushikTTT
(BOB member since 2005-02-24)
It is throwing an Multi Value erro.Do you have any other Code?
Pooja
ktm
if you are placing in the cross-tab footer,
%=Sum([Total Population])/Sum(Total Population) In Report
KhoushikTTT
I have to make one Column next to total population column and have % of total Population.
It is not working, In the column it has Population and at the end of the cell it is Sum(Population).
Pooja
ktm
Could you paste the formula you are using.
KhoushikTTT
