system
1
Hello All,
I have a one object which is date format and format is mm/dd/yyyy.
I need to make a filter in the universe so that when i use into the query filter it will give me the last month data.
Like for example i ran report today :1/10/2011.It will show me the last month data.
like 12/1/2010 to 12/31/2010
The column/ table is “Transaction/Date”. I am using My SQL 4.1.22
Pooja
ktm
(BOB member since 2008-11-12)
system
2
check this thread for creating objects in Oracle and SQL Server for Prevoius months. Use something similar for your database and use it.
https://bobj-board.org/t/152613
BO_Chief
(BOB member since 2004-06-06)
system
3
Semantically, you can run the report for Last Month by using following:
Month_Of(Current_Date - DayOf(Current_Date))
Modify the syntax for MySQL
aneelf (BOB member since 2006-05-15)
