How to make combo box properties enable
Some of the options in Combo Box properties are disables, can anyone help me to make those enable.
below options are disabled.
Always Expand
Open On
Update On
Open Direction
I belive you should assigne the label values and then check the option to enable this.
Jeswin :india: (BOB member since 2009-07-01)
not working, can you provide screen shot if its working fine for you.
