How to load data in SAP using BODS
Hi Guys,
I need to save some information in SAP using BODS, I saw that there is the option to use the IDOC, but I have no idea how to use it, there is another way to do this? Somebody have some material about to use the IDOC?
renato_matsumoto (BOB member since 2013-11-06)
Lot of material on internet apart from iDOC standard BAPI functions can be used. Please check Check SAP Note 1791183 - Rapid Data Migration to SAP ERP and SAP CRM V3.42 for download and installation instructions.
Cheers.
Shaz
Shazin :india: (BOB member since 2011-07-19)
