How to know which version we are using?
can you please tell me how to know which Business Objects version,service pack installed on system.
Thanks in advance.
dearnp (BOB member since 2006-02-24)
Go to BO menu Help -> About Business Objects -> you can see here the BO version and if any SP/patch is installed.
Hi Marek Chladny ,
Currently i am working with Business objects XIR2, i want to find out which service pack we are using. I didn’t find any information in the above mentioned path.what i did is,i just logged in to the Infoview and i click on the help button.Am i seraching in the wrong place?please guide me.
Thanks in advance.
For Patches check History file on this path - C:\Program Files\Business Objects\BusinessObjects Enterprise 11.5\Patches.
Hope this help you…
BOpat :us: (BOB member since 2006-11-09)
This is path where you will icons for different tools like designer,deski,import wizard:
C:\Program Files\Business Objects\BusinessObjects Enterprise 11.5\win32_x86
Right click on icons to go to properties and go to version to look at the version. My import wizard version is 11.5.8.897.
With this version number can we check about Service packs and fix packs anywhere.
hartford27 :us: (BOB member since 2006-11-22)
Do we have any documentation for this Version? So we can identify file version with Service Pack/Patch level.
I am trying to find such documents. i dont have any right now.
To verfify if you have SP2, go to the control panel and add remove programs,check for the service packs there.
Yeah, that works. Thanks.
The easiest way perhaps is to log-in to CMC, get-in to “Settings” and under the “Properties” tab you would find “Product Version” mentioned!
RahulH :india: (BOB member since 2007-05-16)
Remember that server components are separate from client components. Ideally they should be in sync but its possible to upgrade your server components and neglect to upgrade the client components.
Thats the beauty of using WebI, no client components to upgrade.
bension (BOB member since 2005-09-01)
