I’m in the process of setting up some new BCA, and was getting annoyed with each time having to configure the Console to show me the columns that I wanted. I thought I’d post this tip here in case it’s of use to others.
Disclaimer: This involves modifying the registry, so if you have any doubts, then don’t. If you don’t know what the registry is, you shouldn’t be trying this. You can seriously balls your computer up if you get it wrong.
The assumes that you have an existing agent with the the Console columns selected that you want, and the order you want them. Go to regedit and search on the name of your agent. You should find a key called something like
[HKEY_CURRENT_USER\Software\Business Objects\BusinessObjects\5.0\YOURAGENTNAME User Prefs\bcs\BCS]
Export this key, edit the resulting .reg file and simply change YOURAGENTNAME to the name of the other agent(s) that you monitor. Import this into the registry, and Robert’s your father’s brother. ![]()
Cheers, Robin.
RobinM
(BOB member since 2003-02-25)
