How to hide the rows based on Null values in measure object
I have a situaton where i need to hide the rows where ever i get nullvalues in the measure object.
I tried by using filters and able to filter it,but it is filtering to a paricular prompt or table .When users selects diffrent prompt, a new data will be coming in the report and null values are visible again.
can u please suggest me how to filter the nullvalues globally.
panduswapna (BOB member since 2008-08-01)
Are you having many tables/blocks? Are you able to apply a global filter? Or did you try to filter out the NULL values in the query itself by Is Not NULL operator?
