how to get sql for a list of reports using VBA
We want SQL for a list of reports. Is there any VBA code for this.
allimina
animilla (BOB member since 2006-10-07)
There is a utility here …List objects used in a series of reports … that should serve as an example. It collects detailed information about the objects used in each data provider, but you could simply it to capture the DProv.SQL property.
Hi Dwayne,
I think that is not the solution for the problem that i have in hand. Let be restate my problem. I want SQL for each of the reports that are there in the repository. So we created a list from the repository for all the reports that were present there. Since we have lot of reports. What we want is , is there any way we can generate SQL used by the reports using the list that we created through VBA.
allimina
The technique I outlined earlier does assume that the reports have already been downloaded to a local directory. If you have a list of reports, it is possible to use VBA to retrieve them individually by name. I don’t have an example handy, but look at the .Receive method. There is no way to avoid having them stored locally, and opening each document in order to get the SQL.
