Can anyone please tell how to locate the PAR files for Business Objects XI R2 for all Service packs? A search on the SAP site is like hitting a brick wall.
I would appreciate it much.
Thank you.
edyl (BOB member since 2005-10-03)
Thank you.
I agree it is very frustrating to find anything in there…
Go to
http://service.sap.com/bosap-support
in the main window there is a section “Find Documentation” - in this section there is a link “Supported platform documents”; click this link
the page that you will get next has Navigation on the left - scroll down to “BusinessObjects XI Release 2 / Crystal Reports” and click this link
HOPEFULLY all the PAR (Supported Platform) guides you require are there (click the ARROW beside BusinessObjects Enterprise to expand it) - if not they are probably hidden in the Software Download section - good luck finding them
buzz (BOB member since 2005-08-12)
Thanks for pointing me to the right direction, i got the ones that I was looking for.
