I have a report that utilizes three measures, along with a dimension to display in three (one for each measure) columns in a stacked vertical bar chart. What I get when I build the chart the usual way is one column each for each of the dimension values, rather than one column each for each of the measures. How can I “rotate” things so that the columns represent each of the measures, and each column displays the percentage that each dimension value contributes to the total? Let me know if I’m not being clear.
It can be done (charts in BO are dangerous to make a statement like this).
Attach a sample set of data. I will have a better view of the data and the request you have mentioned.
