How to generate same numbers for a group of data
i need to generate same numbers to the set of data in a group.
My Source table holds
PRID TRID
5 2
9 5
10 5
15 7
45 9
89 9
97 9
I need to generate a group id with below data
PRID TRID GroupID
5 2 1
9 5 2
10 5 2
15 7 3
45 9 4
89 9 4
97 9 4
when i used gen_row_num_by_group() i am getting the groupid data in the below table order,but i would like to get the groupID data in the above given table order.
PRID TRID GroupID
5 2 1
9 5 1
10 5 2
15 7 1
45 9 2
89 9 3
97 9 4
Any idea on how to do this.
kiran344 (BOB member since 2010-04-12)
gen_row_num() - gen_row_num_by_group() + 1 ?
HerdplattenToni (BOB member since 2011-05-13)
Hello Toni,
Thanks for your reply,
do i need to include column ‘‘TRID’’
gen_row_num(TRID) - gen_row_num_by_group(TRID) + 1 is it what you are saying wright?
gen_row_num() doesn’t need a column as parameter, that wouldn’t make much sence since it’s just enummerating all rows.
gen_row_num_by_group(TRID) is correct though. And you need to sort by TRID in a query before that. But I guess you have figured that out already since you tested that function before your first post.
edit: I should read the examples more carefully. My “Formula” won’t give you what you want since the output would be
RID TRID GroupID
5    2    1
9    5    2
10   5    2
15   7    4
45   9    5
89   9    5
97   9    5
If you want to get to your solution youll need to Split your input, do a distinct TRID and gen_row_num() as output in on one branch and join back to the other branch on TRID
Yes. Generating the sequence id for each group and then, joining back to the main data would be the only the solution, I could think.
:slight_smile:
VJ
ganesan.vijaykumar (BOB member since 2009-09-09)
I would think of writing a Custom Function which uses the previous_row_value() function on a sorted source data (Sort Order : TRID, RID)
–> Assign a Counter with value 1
–> Whenever the TRID changes, increment the counter
–> If it don’t change by comparing TRID = previous_row_value(TRID) then don’t increment
Hi ganesh,
can you please brief on achiving this using custom function.
Hi Ganesh,
When I am trying to use previous_row_value() function on grouped and sorted data in Custom function, it says we cannot use this function. If you could guide me how I can access previous row value in custom function with or without using Previous_row_value() would be very helpful.
thanks in advance.
BOBJFan (BOB member since 2011-09-24)
